Hey guys & gals
Using a couple of other forums now that have smaller limits as to what you can have in your sig, and was wondering if someone wanted to have a play with some pics and see what they can come up with for me :( I don't have photoshop, and i'm really not that creative, so any help would be awesome! I have no particular layout requests, just that the final sig include somewhere, the words impact_blue along with the following pics
As I said, I have no experience with these things, so if someone has an idea that can't use the pics given, but I could possibly supply some others, lemme know.
Cheers, Anna.
https://www.sau.com.au/forums/topic/154086-sig-request/
lawl. Thanks spammeh.
I have had a thought, and I would like the kitty and the words to be kind of faded into the anime pic. Like, the anime pic is the main sort of 'feature' and the words and kitty are layered over it...
:no: Am i making sense
https://www.sau.com.au/forums/topic/154086-sig-request/#findComment-2866004
WAIT! I've just been looking closer, and i've realised kitty is wearing her bow on the wrong side. Mimmy, her sister, wears her bown on the left (as we are looking at her). Kitty's bow is on the right side (as we are looking at her). Are you able to change this for me puuuuhleeeeease?
https://www.sau.com.au/forums/topic/154086-sig-request/#findComment-2867560
Hey there im glad u like the sig..but i am a bit confused about this kitty thing sorry haha
I'll do a quick change if i can.. but are u reffering to the kitty next to the name that has the bow on the wrong side or the kitty from the exhaust pipe faded on the left of the sig that has the bow on the wrong side
https://www.sau.com.au/forums/topic/154086-sig-request/#findComment-2868919
she is refering to the kitty on the exhaust pipe..
CORRECT! Sorry for confusing you :P The bow on the kitty exhaust pipe is on the incorrect side. Just needs to be flipped.
And tell me to take a hike if i'm pushing my luck... but while you're at it, can you replace the kitty near the words with the cherry blossom below? Just the flower, not the black bits around it...
Thanks heaps!! :sorcerer:
https://www.sau.com.au/forums/topic/154086-sig-request/#findComment-2869302
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
