I'm looking to purchase some front splits for my '97 r33 series 2, should I get 5.25" or 6.5" for the front? Will be looking at purchasing the mbquart qsd216 6.5 or the 5.25" if they 6.5" wont fit in off ebay USA
It says the mounting depth for the 6.5" is 63.5mm
http://www.mbquart.com/all/downloads/einbaumasse/q_216.pdf
I also have a pair of boston z6 6.5" splits to install too, I will be probably putting these as the rear speakers because the crossovers are very big and I dont know where to put them. Will this be a good idea? Or should i just install the bostons in the front and the mbquarts in the rear? Speakers will be running of a pheonix gold titanium 500.4 75watt 4channel amp. Any suggestions will be appreciated!
Edited by sumguy
https://www.sau.com.au/forums/topic/157827-buying-new-splits/
Go for the 6.5 inch spilts on the front.. It will sound a lot better with a bit more mid bass..
(yes the stock pods can hold the spilts- needs a little triming tho.. search for my thread -Hertz front spilts installed.. has a few pics etc etc)
Also i dont think the 5.25 spilts will bolt to the stock pods.. 6inch will deff fit!! hard to find..
I put my crossovers in the doors.. As in the gap where you put your street directory.. Fits perfectly for mine!!
As for what speakers to put in the front and rear.. well it comes down to your ears.
No need for spilts on the rear..
Edited by siddr20
I have a 97 R33 S2 as well and i put a set of alpine type x splits in the front and back, both 6.5", The front speakers went straight in without modifying anything and i put the tweeters on the part that covers the wiring for the side mirror electrical wires, Definatly get sound deadening as skyline doors sound like absoloute shit without them, I am getting my doors done around august as well as my boot. I also have the crossovers in the same place as siddr20 With the wiring running back into the door, it looks good. the back i had a bit of trouble with, My car actually never came factory with parcel tray speakers (no idea why) and the people that had it in japan had a set of 6x9 pods that they took out before selling it (i could see the marks that it left) So i just took the factory parcel tray out and then made one myself out of MDF, just re covered it in carpet, and put the air vents in and cut out the speaker holes.. Was a bit dodgey getting the speakers in had to make some "modifications", And i just mounted the tweeters flush inside the rear side panel on each side in the interior, Right where your ears are if your a passenger :laugh:, I have the crossovers mounted in the boot next to the amp.
(yes i am aware that it is on an angle, Its my first time at doing things myself haha)
Edited by OBNXSH
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
