rego till april 07...
auto...
engine done 50,000kms...
car done 95,000kms...
BLITZ front mount intercooler...
8 row oil cooler...
exhaust w/ cannon tip...
K'n'N pod filter...
TURBOSMART Boost controller...
Brand new metalic blue Respray...
HKS rear drift wing...
GTRS front bar w/ mesh...
VERTEX side skirts...
Standard rims...
cd/mp3 player...
clarion 6s all round...
had enough of the old skyline and want to upgrade......
i will be puttin pic's up this weekend in the meantime pm me for anymore details car is in sydney city and i want 12.000
Edited by FR33ZE
