Hi ppls,
I have a set of 6bolt half shafts to suit a VLSD diff with a tight viscous hub and spider gears.
The viscous hub is nice and tight, zero signs of overheating, its in excellent condition.
This package is good if you don't yet have the $$ to go all out on a diff center yet want the strength of the GTR's bigger axles and a tight lsd.
Essentially:
Remove your diff center, split the casing, remove the old spider gears and viscous hub, insert the tight viscous hub and spidergears. Reassemble the diff center, place it in the housing then slide in the 6bolt VLSD half shafts. Bolt up the axles and your done.
Easily done at home you don't need specialist tools to setup backlash etc as you are using your origional center, just changing the guts of it to suit the stronger 31spline 6bolt halfshafts/axles.
For the lot, spidergears, tight viscous hub and 6 bolt half shafts:
$50 + Postage
I have a set GTR/GTS4 Axles for sale here - http://www.skylinesaustralia.com/forums/in...=0#entry2987016
SOLD
