Hey guys,
Coming from the rear left hand quater of my series 2 R33 i have this annoying ass rattle at all speeds, Now its far back enough that im thinking possibly exhaust but everything looks tight! If anyone has had anything similar to this please tell me! It sounds kinda like something hollow banging against something. Defiantly more noticeable over bumps. Its also not the spare tyre, battery jack, catalytic converter (just imported so should be brand new) or tools.
Cheers for any help! This is bugging me!
have a look in the little alcove where the jack sits. make sure the jack is tight, and stick your hand down in the hole and see if there is anything in there. i found 2 toy cars, some makeup and a few other things in there when i checked mine.
^^^^ Yeah I second that. I had this annoying rattle in the back whenever I turned corners. Finally put my hand down beneath the jack bracket and found a roll of electrical tape and a screwdriver. Never heard the rattle since.
if its on the left side...try checking to see if the antenna mask is loose
lol check for loose golf balls aswell. i was out at nightcrawlers house the other day and was sick of the rattling so i went through the tool area and found some spare golf balls, they make a lot of noise :)
Ok, its the friggen muffler.
It only happens when its been running for awhile so im guessing that the metal expands and something inside is then rattling around. Its the stock muffler and i cant see anything to tighten so i suppose its after market time!
Cheers all
  • 5 years later...
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
