RB25 Turbo - under 1mm shaft play - good nick made 209rwkw on rb25 on 12psi with fmic and fuel pump - $300 (will incl freight anywhere in oz at this price)
Got 2 RB25 Turbo Elbows - with bolts - $60 each
RB20DET motor - Bottom End knock - $200 - Sold
RB20DET Head - Perfect Condition - Incl Inlet Manifold Bottom Half - $120
RB20DET Gearbox - Was a bit notchy into gears and whined in 3rd and 5th - sold as suit rebuild - $150
RB20DET Gearbox - Was a bit notchy into gears - synchros seemed fine - $250
RB20 Turbo - minor shaft play, seems good - $150
in Brisbane
Edit: Added Turbo
Edit 2: Added RB20 Turbo
Price are negotiable
pics below
Edited by 040jqm
RB20 Turbo picture - comes with elbow
I coulda cleaned it up with a wire brush - but why!?!?!
Least now u can see it in its genuine state!
Edited by 040jqm
  • 1 month later...
Dude I will take it depending on where you located.
Cheers
Sam Murray
Msg/call me on 0405622444 as I dont get on here much.
  • 3 years later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
