For Sale is the Gizzmo IBC - Intelligent Boost Controller.
This is the Control unit only - will need a solenoid to operate - you can get a solenoid from www.tweakit.net.au for $125. - its the same as the Haltech one.
Simple two wire installtion
4 boost settings
Unit doesn't gome with manual - but you can download it from the Gizzmo web site : http://www.gizzmoelectronics.com/pdf/IBS%2...n%20Ver1.06.pdf
$75 plus postage
Grab youself a bargain -
https://www.sau.com.au/forums/topic/167380-electronic-boost-controller-75/
