2002 Subaru WRX
300kws at 24psi with 98ron
???kws at 30psi with C16 + Nos
Previous owner has done an
11.63 @117mph car now make 70-80kws more at same boost levels
Engine
• Stage 3 Trp race engine has done 6200km
• O ringed 2.5ltr sleaved close deck block
• Ceramic coated pistons
• Nitro treated bearings & cranks
• Heads are deck & O ringed
• Copper head caskets
• 14mm Head studs
• Custom Cams
• Custom Extractors
Turbo
• T60-1 ceramic twin ball bearing
• Turbo with K&N air filter
• 3" ceramic coated down pipe
• 2.5" ceramic coated up pipe
• 38mm external waste gate
• Blitz electronic boost controller
• 3" stainless steel exhaust with cannon
• ECU micro tech LT8's with 3 bar map
• Sensor & hand controller
Accessories
• Polished alloy front mount intercooler & pipes
• Polished over flow bottle & catch can
• Engine plastic ceramic coated red
• 125hp wet nos kit with purge kit – Zex brand
Fuel System
• Adjustable Malpassi regulator
• 800hp external Bosch fuel pump
• 2Ltr surge tank
• 850 Injectors
Drive Train
• Sti 6 speed Oz spec
• Custom TRP race clutch
Body & Paint
• Jetspeed body kit
• 2 pac purple engine bay
• Wingless boot lid
• Clear blinkers
• Sti lights
• Carbon fibre bonnet with 03 bonnet scoop
• M3 style carbon fibre mirrors
Suspension
• Adjustable coil overs all round
• 18 x 7.5 gold forged Ray's wheels
• 2 piece DBA 5000 rotors
• Freddo racing brake pads
Interior
• Tan leather
• Carbon fibre Sti door inserts
• JVC Dvd player and screen
Everything has been done for you
Some pic
Price: $45,000
Edited by mattj255
https://www.sau.com.au/forums/topic/168157-fs-2002-wrx-300kws-new-pics-page-2/
  • Replies 41
so wats this thing like on petrol, and wats it like driving on the street??
If you just drive it normal its good on petrol....if you drive it hard it gets thirsty :)
Driving on the street its just like other cars....just faster :rolleyes:
No. the buyer didnt have the money
Hi Matt,
as i mentioned on rexnet, a buyer with a zero rating thats been registered on ebay for less than a week ISNT a genuine buyer. You should only accept bids from people that have phoned you or some other requirement to somewhat satisfy you of their intended genuineness. Not 100% fool proof but pretty good.
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
