This is a brand new in the box Belkin G+ MiMO router. Comes with every thing needed.
Sydney City, or Bankstown
$130 firm RRP $199 incl postage
Product Information
* Provides greater coverage than standard 802.11g with improved
reliability and fewer drops.
* Improves performance of standard 802.11g and 802.11b networking devices
* A Belkin G+ MiMO router used with an older 802.11g or 802.11b networking
product increases wireless coverage up to 10%.
* Improves resistance to wireless interference
* Delivers higher networking speed in a mixed-mode environment
* If a standard 802.11b device is introduced into a Belkin G+ MiMO network,
the Belkin G+ MiMO product will not drop to the standard 802.11b speeds.
* Provides advanced security: WEP 64-128 bit WPA-WPA2 support
* WiFi Certified
* Supports PPTP, PPPoE, IPSec pass-through protocols.
* Supports Bigpond cable heartbeat.
* Restricts Internet access by time of day to specified PCs
* Configures easily via a web browser
* IP Sharing Method: NAT (Network Address Translation)
* Firewall: NAT, SPI
* Clients Supported 253
* DHCP Server: Supported, User-Defeatable
* User Interface: HTTP/Through Web Browser
* Belkin Lifetime warranty
BELKIN Code: F5D9230AU4
www.belkin.com/au
PM only guys
Edited by ATTN
https://www.sau.com.au/forums/topic/170415-fs-belkin-wireless-router/
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
