RB26DETT Complete Engine R32 $4800.00 inc turbos inlet manifold throttle bodys etc PRICE DROP Now $4500.00
1x R32 GTR Air Con Compressor $150.00
1x R33 GTR Air Con Compressor $150.00
2X Micky Thompson Slicks Brand New 26"x8.5" $500.00 (new Price $800.00)
1x RB20 Air Flow Meter $100 Price drop $70.00 SOLD
RB26 Con Rods $200 (several sets available)
RB26 Crank R32 spec needs machining $200 (Perfect for RB20 Stroker RB24 several Available)
SR20DE Cylinder Head $250
Turbonetics External Waste Gate $300
Apexi Powewr FC with hand controller Suit R34GTR Brand New $1300.00 SOLD
Apexi Tmax Coil Overs Suit R33/R34 GTR Brand New $500.00 per set (Firm)
R33GTR Drivers seat perfect condition with rail $450.00
Contact Darren 0417305401
Edited by dazmo
  • Replies 62
Posted Images
The engine does not have altinator,A/C compressor or coil packs but is otherwise a complete engine incl turbos manifolds inj etc.Am not 100% on klm's but the head if off the engine at the moment so i can arrange to send pics of the bores to you or if you are local can arrange for you to inspect.The head has just been reconditioned as i bought the engine of a guy that had a friend change the timeing belt and stuff it up so the piston hit the valves on start up and then obviously would not run so i have had the valves replaced and the head fully serviced there is no damage to the pistons whatsoever and the bores are in perfect condition.I will reassemble the engine with all new genuine nissan gaskets (head inlet exhaust throttle).
any blocks darren? what comes with the complete engine? turbos, injectors, manifolds etc. how many k's etc.
No sorry mate fronts only.Wishfull thinking to get front and rears for that price full sets usually sell for around $2000-$2500.00.
Are the brembos front and rear for 1600?
If so please PM me :P
haha yeah, never hurts to check :(
Yes the coilovers have full hight and dampening adjustment but do not come with springs.You can purchase spring from kings springs for $300.00 for a set of 4.
:) thats no problem at all mate was good to catch up. Am always happy to help.
Hey Darren, good to talk to you today mate!.....looks like one handy person to know if you own a Skyline esp GTR and a top bloke too!
Kwei
Cheers mate you should see my new silver ozzi delivered one car no 1 of 100 the first GTR to ever enter oz in mint stock standard condition 77000klms wich Nissan australia actually owned for the first ten years would definatly be one of if not the tidiest R32GTR in the country.Definatly a collectors item for any GTR nut :D
Nice Aussie Black 32
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
