  • Replies 62
Posted Images
  • 4 weeks later...
keen to sell the throttles at all? pm me if you will:)
thanks
Craig
Sorry mate do not want to seperate engine and if i do end up seperating it i would be selling the head complete.
  • 3 weeks later...
  • 1 month later...
hello, how are you?, i am interested in the rb26 as mine is in need of a freshen up and just pricing up my differrent options. would you consider selling it without the turbos? if so how much? and where are you living at the moment, and do you have reciets of the work carried out on the motor? thank you.
I live on the gold coast the engine in this post has been sold but i do have another engine that i just removed out of my R33GTR engine was running in perfect condition (reason for removal is due to a whole new engine being fitted as i am builing this car as a dedicated track car) the car ran 12.6 1/4 mile with this motor fitted with stnd exhaust and paper air filter and the factory boost restrictor removed so is a good healthy engine. the engine has done 110 000 klms and as stated is out of a R33GTR so has the better crank ect. As stnd GTR turbos are not really worth much on their own I would prefer to sell the engine complete I want $4700 for the complete engine wich is a good price for a perfect condition R33GTR engine and certainly much cheaper than even a stnd freshen up. Phone or PM me if interested Daz.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
