Hey guys,
I regretfully have to let my baby go due to a property opportunity that has come up unexpectedly. These are very rare and the only one I know of in Victoria. Please see link for details;
Amazing performance from a fairly standard car (1JZGTE & automatic)
Rare Warm Grey Pearl colour * Rare factory Sunroof * 17in alloys * Genuine 106000 kms (Timing belt replaced etc) * Pre-purchase inspection report on hand * 11 months Registration * Victorian issue 'JZX' numberplates * Very rare car in Victoria, have not seen another * Car was unmodified when purchased, now has full stainless exhaust system (RS*R front pipe & HKS cat-back system).
http://www.carsales.com.au/used-cars/priva...e|1&trecs=9
Pics:
http://i146.photobucket.com/albums/r268/itstok/4.jpg
http://i146.photobucket.com/albums/r268/itstok/3-1.jpg
http://i146.photobucket.com/albums/r268/itstok/5.jpg
http://i146.photobucket.com/albums/r268/itstok/1.jpg
http://i146.photobucket.com/albums/r268/itstok/2.jpg
Pics of imperfections:
Chip behind passenger rear door:
http://i146.photobucket.com/albums/r268/itstok/chip.jpg
Marks on rear bumper:
http://i146.photobucket.com/albums/r268/it...bumpermark1.jpg
http://i146.photobucket.com/albums/r268/it...bumpermark2.jpg
Marks near sunroof:
http://i146.photobucket.com/albums/r268/it...unroofmarks.jpg
Slight ‘rise’ on passenger side front door:
http://i146.photobucket.com/albums/r268/it...ssengerdoor.jpg
Drivers seat wear:
http://i146.photobucket.com/albums/r268/itstok/seatwear.jpg
Other pics:
http://i146.photobucket.com/albums/r268/it...lianceplate.jpg
http://i146.photobucket.com/albums/r268/itstok/eng1.jpg
http://i146.photobucket.com/albums/r268/itstok/eng2.jpg
http://i146.photobucket.com/albums/r268/itstok/boot.jpg
http://i146.photobucket.com/albums/r268/itstok/int1.jpg
http://i146.photobucket.com/albums/r268/itstok/int2.jpg
http://i146.photobucket.com/albums/r268/itstok/rhf.jpg
http://i146.photobucket.com/albums/r268/itstok/lhf.jpg
http://i146.photobucket.com/albums/r268/itstok/rhr.jpg
http://i146.photobucket.com/albums/r268/itstok/lhr.jpg
Thanks for looking.
Chris
Edited by YSR020
trade my 32 sedan chris serious :(
mmmm nice car and free bump
Yeah man, bring it 'round and we'll do a deal... ;)
Bump for a FURTHER price drop...now only 11.9k! (without plates)
*also take another $500 for interstate buyers as I will refund registration
Someone take this beast and help me get this property!
Was this parked at levanswell road in moorabbin yesterday afternoon?
By the time i realised what type of car it was it was too late to check it out properly as i had to head back to work... if it is it looks awesome. Pics dont do it justice
Sorry mate, not this one? I'd be interested to know if it was a Tourer V? I've never seen one here...and neither has anyone else on JZX90.cpm?
Either way...pics don't do my car justice either...will get better ones asap! :P
Cheers,
Chris
may have been a chaser... looked almost identical... wheels n all.
definately awesome cars and at that price its a bloody steal... good luck with the sale.
If it does not sell within 1 week I will miss out on this property and car will be off the market...no further price drops...I would rather keep it...people coming to view it this weekend...final chance.
This listing (230172657916) has been removed or is no longer available. Please make sure you entered the right item number.
If the listing was removed by eBay, consider it cancelled. Note: Listings that have ended more than 90 days ago will no longer appear on eBay.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
