i have one from JSAI it is firbre glass i have made a fair few cuts in it, i was going to use it but decided not to as my skyline is no longer daily driven, if you are interested let me know and i will sort out a price with you via PM
Im actually after one too as last week was pulled over by nice officers.. leave the BOV defect wheels lol.. but thankfully they let me off with a warning to cover pod up ..(induction noise issue)...
spoke to Choy he said theres a guy on here with user name MAXX ??.. sells alloy enclosed CAI boxes with clear top .. im trying to find out if his still active on here
Yeah.. i checked with him already.. he don't make it anymore.. :D
Vince ive got a template made already for 33 / 34 without custom piping IE stock piping system .. sat we should tee up a time and spend it cutting it out on to a platic or arcrylic sheet ?
ok thanks Vish.. will tee up on Sat.. :banana:
I found a shop that sell alu plates as well.. CAPRAL Aluminium at Slacks Creek.
May be we can make an aluminuim box with a clear top. ;)
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
