I have had a few ppl interested in a pair of the R33 and Supra wheels i have posted.
If you are interested in a pair only please post here as I dont want to separate but if there a ppl wanting a pair each then we can work something out.
thanks
https://www.sau.com.au/forums/topic/182008-pls-delete/#findComment-3345666
    • Well, this, but braided line to the sender that is mounted on the chassis. Oil Pressure doesn't need to be close, while I prefer Oil Temp is in the active oil flow (bro science, not sure how much it matters).  That's how I've had mine set up for years and it works OK
    • Welcome back! There is a v series forum, a little quiet at times but every new active member helps
    • But, per MBS206's question, what happens when it doesn't start. When you turn the key to IGN, do the dash lights come on (then go off after a couple of seconds) - likely alarm or other electrical issue When you turn the key to STRT do you head a clear click (the starter solenoid trying) without the engine turning (likely starter motor)
