You'll basically have boost at idle. :thumbsup:
My GTSS's come on well and truly be 3000-3300rpm from what i can gather... too busy watching the road as its all over the place
And thats with the stock management still. No tuning or anything.
On a 3ltr... it would be somewhere in the 2000rpm range id imagine. Would be very torque filled but i'd imagine would die in the upper RPM somewhat
Cheers thanks for that do you think theirs any way I will achieve 300rwkw?
Theyd be good without being great. It would drive like a naturally aspirated motor :P
Id be itching to use that displacement to full effect with some 2530s though. Sell the ss's for 2k and put that towards something else perhaps?
........Then again i just saw youve got a vl.
If its an SL auto then 300rwkw is more than enough for some lightning times
More power creates more traction issues obviously
My car weights in around 1400kg's or so, if it was a 1250kg VL... jebus.
I was told the car will feel like a 3.5ltr N/A, and it honestly does. Very strong.
Whats the use of the car?
That will have some gauge on what you want/dont etc.
More power poses a problem in a way, depends how linear it is. Light-switch style is harsh as its just all over the place from nothing
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
