my friend owns an r32 gts-t, stock springs, shocks, rims/tyres, steering wheel etc.
he showed me today a puzzling problem how the steering is normal up till about 65-70km's, which then the steering wheel automatically turns to the left roughly 15 degrees while the car stays straight and remains there.
if you slow down under the 65-70km mark, the steering wheel then turns back to 0 degrees while still staying straight. pretty tripped out!
he's had no smashes or anything like that.. does anyone have any idea what would be causing this?
https://www.sau.com.au/forums/topic/186876-wierd-steering-issue/
sounds like the hicas is turning one way and so he is automatically correcting.
remember that the steering wheel has a connection to the rack, so if the steering wheel turns you are turning the front wheels, the steering wheel just can't turn on it's own without turning the wheels.
problem. the hicas controller is stuffed. solution. replace the controller or get a lock bar.
it happened to me but it was a bit random and generally when accelerating hard, so i locked the rear rack.
My car used to do something similar, the wheel always sat about 10deg left of centre and at about 80km/h when accelerating hard, the back end would get a bit quiggly for a couple of seconds - only around 80km/h.
Removed the rear steering rack yesterday and whacked in a lockbar (cheers NV_01), steering wheel now sits straight and no more squirling in the back end..
I can only assume I've been crabbing along for a while now O_o another thing I noticed was that when reversing out of my driveway the wheel would sit about 10deg to the RIGHT, then left again when moving forward. I think hicas was fubar'd!
THANKS FOR THIS INFO GUYS!!! I thought I was just going crazy with my R32 because on the freeway the steering wheel would sit to right but when I was driving in normal streets (60k zones) the steering wheel would be straight. Might have to convince the g.f to let me get a lockbar and see if that fixes it.
Why did nissan even put these hicas systems in in the first place. Everyone takes the bloody thing out.
Yeah i had similar problem on GTR locked the hicas and never done it since, very unsettling, and weird when you tell people and they say no that can't happen, Yeah well we know different, It can and it does.
PJ
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
