Hi guys
Last week the power steering on my car decided to stop working, steering became quite heavy, so I went ahead and checked the usual suspects.....
- speedo is working
- belts are fine
- fluid is fine
So I thought "the pump", went to my local wreckers and got myself a new pump, installed that and to my surprise it didnt fix the problem, went back to the wreckers to ask for another pump, got that, went back home installed it.....nothing AGAIN :) .
So now Im thinking what are the chances that both these pumps were dead? I believe the problem may just be somewhere else, but dont know where to start looking now.
So if you guys can give me any ideas, that would be sweet, this is doing my head in :)
Cheers
Ric
Edited by Richo
https://www.sau.com.au/forums/topic/187267-power-steering/
Try searching under hicas problems, but if that fails here's my suggestion for the pump itself.
open up the pump and check the magnets inside, if you see any sign of wear inside the pump, then there is contamination somewhere in the entire power steering pump system. By changing pumps only you're actually causing the shavings to cycle through each pump you put on the car.
You could have shavings, cycling from the steering rack, through to the pump. Whilst you are there, your pump may have some type of pressure switch setup, and it may not be working properly. From what I remember when i checked mine on an R33 and R34 pump, there was a spring and ball bearing type setup that you can get to, to see if that area is releasing freely.
https://www.sau.com.au/forums/topic/187267-power-steering/#findComment-3381289
Thanks guys, ill have a look at the PRV (if I can find the thing) :( and the fuses and see how i go
FYI.. I looked under the car and the right hand side steering rack boot was completely destroyed, I had noticed that it was split a few months back, but now its totally open and perhaps letting alot of crap in to the system. Any way of flushing and cleaning the PS system , or is it a matter of getting a whole new rack???
Cheers
Ric
https://www.sau.com.au/forums/topic/187267-power-steering/#findComment-3382751
I found a blown fuse on the dash board, at least we are getting somewhere here. :(
Now does anybody know what this fuse controls? I just dont have access to a new fuse now, being public holiday and all.
Cross fingers thats the answer though.
Cheers
Ric
https://www.sau.com.au/forums/topic/187267-power-steering/#findComment-3382931
Cheers
Ric
From memory it was a 15 or 20A fuse that blew in my bro-in-laws car. Looks very familiar. I noticed you have a 10A and 20A in the spare fuse holders. You may be able to try a 10A if it is a 15A that blew. At least to get you going until you get the correct one.
Cheers
https://www.sau.com.au/forums/topic/187267-power-steering/#findComment-3382970
edit:
Ben mate, you were right on the money, the blown fuse on the loction shown on the pics is a 10A....now Im not sure whether this fuse is purely for the PS but I put on one of the spare 10A's on there and voila!! PS is sweet now!
Hope this helps any one in the future, check your fuses and go from there.
Thanks again Ben, and to the others for the suggestions :D
Ric
Edited by Richo
https://www.sau.com.au/forums/topic/187267-power-steering/#findComment-3383256
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
