:closedeyes: Am wondering if anyone can help me? I own a povo pack skyline(pintara) which has a miss under excelleration and stalls failing to start again. The mechanic said spark is ok also fuel and fuel pressure. Any clues on what this could be? Thanks..
forgot to mention motor is an CA20 also it smells like it's running rich
Edited by sad pini
https://www.sau.com.au/forums/topic/189861-flatspot/
a bit old for coil packs Eug :D
is this a twin spark CA20?
my first car was one of these CA20 Pintara's, the thing just kept going, this was several years ago now. I did experience something similar to what your car is doing now, my problem was the no.1 injector died. 1 new injector and a clean of the others later and it was back running like clockwork.
https://www.sau.com.au/forums/topic/189861-flatspot/#findComment-3421009
haha ca20...
could be dodgy afm, paddel type! can get gunked up and wont move too freely (giving dodgy readings)
its common for pinny's to fill the airbox/intake piping/afm up with oil, pull it all off, check it and give it a clean, make sure the afm moves perfectly smooth (carby cleaner/elec contact cleaner).
you best be though is to go to - r31skylineclub.com and go to CA20e section.
maybe replace that motor with a CA18DET :)
most parts for the ca20 are easy to come by and cheap, so you can do a bit of trial and error.
cheak in the dizzy etc, could be worn, wind as much timing as you can into it, pinny's love timing and dont ping
also take out the water temp sensor and give it a clean with a scourer (not the dash one the other one - or both) if thats gunked it makes the car in cold start all the time, also check the 02 sensor if you have bad economy issues.
cheers
https://www.sau.com.au/forums/topic/189861-flatspot/#findComment-3421423
a bit old for coil packs Eug :)
Thanks for th reply's ya'll all great help th mechanic my wife[i was at work] organized reckons it's a relay but i doubted this because it ran a bit rough and blowing black smoke upon start up and hard acceleration. yes it is th twin spark motor i actually was going to change th plugs to c if this helped. love th idea of th ca18t have heard about guys putting th head and turbo off the ca18 onto th 2 lt but sonds like alot of trouble to me when there are better options thanks again i'm a new member and crappy on th computer love th site
https://www.sau.com.au/forums/topic/189861-flatspot/#findComment-3422358
haha ca20...
cheers
Thanks skit r34 on th morning it failed to start i noticed a small pool of oil in th air filterbox and thought could be a possible cause
https://www.sau.com.au/forums/topic/189861-flatspot/#findComment-3422692
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
