Age: unknown
Condition: good to excellent
To Fit: any
Contact: 0403008586 or pm me
Comments: all gauges come with all wiring / sensors, prices are pickup only, postage at buyer's expense
Item: Trust - Greddy GRACER Airinx-II Air Filters (Original Trust adaptors included to suit oem meters)
Age: less than 6 months old
Condition: as new
Price: $140.00 pickup $120
To Fit: (What car) R33 GTR
Contact: pm, sms or ring me on 0403008586
Comments: may fit other GTR models? can someone confirm this please
currently $220 at nengun delivered after 2 weeks wait, this is less than 6 months old
http://www.nengun.com/trust-greddy/gracer-...-ii-air-filters
Piping not included, only those circled!
04112007463qs0.th.jpg 04112007461hc0.th.jpg 04112007464ij7.th.jpg 04112007462lp8.th.jpg
Item: Red Line High Temp ATF oil (1quart/.94litres)
Age: new
Condition: Brand New , opened but unused.
Price: $15 pickup or can be posted at buyer's expense.
To Fit: was to be used on my R33 GTR but suitable for other cars?
Comments: GTR had a complete engine, gear and diff oil change and I unfortunately did not order enough for the transfer case. Ended up using some Castrol for this.
Item: Dunlop Le Mans 265/35ZR18
Age: unknown
Condition: used but still plenty of rubber
Price: $140 for the pair... pickup only SOLD!
Item: Duncan / Race Worx Attessa Controller
Age: received in the mail 06/02/08
Condition: Brand Spanker , never installed
Price: 350.00 pickup or posted for free SOLD!
To Fit: (What car) refer below thread
Contact: Jeff on 0403008586
Comments: Reason for selling is Im getting an ECU for the GTR instead.......
Group Buy thread
http://www.skylinesaustralia.com/forums/Fs...77#entry3637877
Item: R33 GTR rear pods
Condition: new
Price: $120.00 pickup (cost me $132.50) or can be posted at buyer's expense SOLD!
Item: Black HKS Exhaust Gas Temp gauge (60mm mechanical)
Price: $120 SOLD!
Item: HKS Turbo Timer
Condition: used but in great condition
Price: $70 $60 pickup or can be posted at buyer's expense. SOLD!
Item: White HKS Chrono DB Boost Gauge (60mm) + Meter Interface Unit
Price: $150 for both SOLD!
Item: Mearcat gauge holder to suit any R33 Skyline
Price: $30 SOLD!
Edited by jeff
https://www.sau.com.au/forums/topic/190818-trust-gracer-twin-filters-12000/
  • 3 weeks later...
  • 2 months later...
Age: unknown
Price: $140 for the pair... pickup only..dropped to $100 for the pair..
To Fit: was on my LM-GT1 (18"x10")
Comments: only selling due to needing to replace front tyres and ended up buying a matching set of 4 for my wheels
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
