These wheels will only fit a GTT with a 5mm spacer on the rear. no guard rolling however and sit perfectly when dropped :ph34r: wont fit a 33 gtst either .. again spacers
I'd buy them and spray them black but im strapped for cash :rofl:
Edited by DECIM8
https://www.sau.com.au/forums/topic/192973-sold/#findComment-3490234
Well I have the exact same wheels ( wide pack ) fitted on my R34 GTV ( turbo brakes & suspension factory fitted ) with NO spacers anywhere. So, unless there is a difference between mine and a GTT they should fit. I'll admit that the gap between the rear calipers and the wheels is small, but it doesn't touch :wave:
https://www.sau.com.au/forums/topic/192973-sold/#findComment-3490429
I had these wheels also on my r33 gtst. and i didnt use any spacers or anything and it filled the gaurds perfectly. not sure where u got ur spacers ideas from DECIM8? but yes the brakes only just fit behind the wheels which sucks. good luck with the sale.
https://www.sau.com.au/forums/topic/192973-sold/#findComment-3490791
Sorry should of specified.. Series 1 33 it will fit.. series 2 it wont due to bigger nissan writing. R34 GTT will not fit them, Gtv may I have no idea .. GT will.
more power bigger brakes..
Edited by DECIM8
https://www.sau.com.au/forums/topic/192973-sold/#findComment-3491029
Does anyone have a pic of white impuls on a gunmetal R32, ive been wanting some in shadow chrome for a while but if it looks decent in white on a gunmetal 32 ill consider these.
I have a set in normal chrome, that pattern looks good on pretty much all R32's
https://www.sau.com.au/forums/topic/192973-sold/#findComment-3492561
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
