PM me or phone 0412558715
Have a set of 4 PIAA ROZZA
17x 7 +38 5 x 114.3 They come with 15mm bolt on spacers for the front and a 20mm spacers for the rear.
Tyres have 65% tread on the front and are at the wear markers on the rear. Tyres are Bridgestone 215 45 17
$600
pics
Also have a set of WORK VIP 3 piece rims.
They are 16x 7.5 and 16x 8.5 5x114.3 The tyres are completly dead.
fronts require a 15 or 20 mm spacer to clear a skyline caliper and rears clear s13 easy with no spacers.
$500
pics
https://www.sau.com.au/forums/topic/193692-piaa-rozza-17s/
    • This is amazing. Love that you’re giving the boys an intro to cars and off the screens. They probably have an insta for the car and build posts on TikTok for their mates.
    • It is.  Your car works fine with the tank full. If you drive like a Nana it works fine.  You give it a boot full with half a fuel tank, you get surge.  It 100% is a fuel surge issue. Maybe have a look at installing a Hydramat if you don't want to install a surge tank.  https://www.holley.com/products/fuel_systems/hydramat/
    • Hanging out in Perth for a conference. Asked for a room with a view… got a view of Bustdown Festival   might stroll down and go say hi to Spotto and some of the hoonfluencers
    • It’s definitely just a problem with my car, as there’s bound to be plenty of 4-600hp cars out there running a factory tank with an upgraded pump and or hanger
    • Ah right, that would be a nightmare as I only get 150ish kms before it starts having issues/half a tank, and yeah if I don’t get into it I could run it completely dry, it’s only when it comes into boost it will start to break up, it also does it in every gear which leads me to believe it isn’t fuel slosh/surge as 4th and 5th shouldn’t have enough power to cause an issue. It’s got me stumped 🙃
