You know what it's like when your missus tells you "The car sounds like it's falling apart, and it's lost power" and I just remembered I'd forgotten to tighten the lower alternator bolt after a fan change, SH!T!
Well, the alternator bolt was still there, Phew! so I ripped a wheel off and the outer sway bar link had clean snapped! I'm using one of Whiteline's 24mm adj blade types in an R33 GTSt sedan.
They said it's not common, has anyone else had this happen?
Does anyone have one spare (or a pair) I could buy? Happy to pay $30 for a pair.
Lost power was probably just some heat soak, that is one good thing about winter here; Power!
Cheers
PS: National Capital Rally on tomorrow - Sat 17th, get out to the Cotter/Uriarra/Brindabella Rd for some dirty action.
