Hi everyone it's my birthday on tuesday and i turn 25 on and i am wanting to do something so i was thinking on saturday night 24 nov have pre drinks at my new house then go to hq at 9pm so all that know me or dont know me and just want to go out, come to hq for a drink or 10 with me for my birthday
https://www.sau.com.au/forums/topic/194060-bunnys-birthday/
  • Replies 50
well i guess ill reply for myself then as flick is being rude :D i believe i shall be there too, along with randall(kristy's other half) hopefully so i know someone.
And you can join flick as being quarter of a century as she likes to put it lol.
https://www.sau.com.au/forums/topic/194060-bunnys-birthday/#findComment-3482300
grand pappys :D
haha, madaz is an old basterd :)
ive got to be onle of the youngest people on here next to blue gts, im only 19 :)
and flick looks younger then me hahaha
oh and happy bday, dont get toooo smashed!
Edited by Import S13
https://www.sau.com.au/forums/topic/194060-bunnys-birthday/#findComment-3482355
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
