hey guys
after having a few complications with my ITS turbo i bought i decided to suck it up and buy a stage 3 slide hiflow, now, i know you have to do some moding to the oil banjo bolt, and i have done a little search but am not 100% confident i know what to do.
would it be possible to just get enzed to make a braided line the same diamater as the stock line except get fittings that are bigger to accomadate for more oil? if i do get this done, what will i have to do about the oil restrictor?
if there is a thread with some more help could you please point me to it as i cant find any LOL
thanks
sam
https://www.sau.com.au/forums/topic/194904-slide-stage-3-hiflow/
you will have to send a PM to Slide and ask for the link to the pictures that show what need to be done (ie how/where to drill out the banjo)
I went to enzed and got a new line made up, leaving them my old line and the instructions that I got from Slide, so that Enzed would get the overall diameter correct for the braided line
good luck with it.
If you want to use the factory oil line you will need to drill out the restrictor with a 6mm drill bit. To get to the restrictor you need to drill through the "banjo housing" (the knuckle bit on the end of the oil line). You will then need to go to a radiator place (or somewhere similar) and get them to braise/weld over the hole in the banjo housing.
Lazy-Bastard
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
