  • Replies 237
Posted Images
Yeah forgot about the time there :)
Thanks 4 the help :cheers:
I was gonna see how long it would take before someone (you) told him :D
HAHAHA!!
No problems buddy.
Im here to help you :) ..........
Hey, what if it.... you know.....
i dont want to say it just incase it does....BUT
What if it... YOU KNOW??!!!!!!
the R word lol
Then what do we do? cancel? post pone?
Guest Joeyz
HAHAHA!!
No problems buddy.
Im here to help you :yes: ..........
the R word lol
Well what about meeting in a carparking lot? :huh:
Tokyo Drift style :)
Then let it be on like Donkey Kong :rofl:
Tokyo Drift style :huh:
Then let it be on like Donkey Kong :yes:
LOL! That is such a "JDM Style Tuning" thing :rofl:
HAHAHA!!! i was just thinking about the time i went to "Night-Shift"
... we were in a parking lot... it was SOOO "Tokyo Drift" LOL!!! :)
I have not been on any of his cruises or any large cruises for a long while. I got to get out more!
YES YOU DO!
Thats why you're going to this cruise aye!
AND! you're going to Megalong Valley cruise!
AND! you're going to Hills meet up!
AND! you're going to sau monthly dinner!
AND! LOL i dunno what else to write!
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
