Hey There
The other week i got pulled over and defected so im chasing down some standard parts. Does anyone in the northern suburbs preferably have front and rear springs to suit an r33 gtst series 1 and how much would you want for them? I will add more parts to this post as i go through the whole process. Also if anyone else has been through regency with an r33 can you please tell me what they looked over just so i can get a general idea of how much work i gota do.
Cheers Allan
Edited by iLEC
https://www.sau.com.au/forums/topic/195891-been-defected/
Yeah mate i know they check everything lol but if we could put togethor a checklist maybe we could sticky it ontop of the page to help everyone so far i know you have to have
-Standard Turbo
-100mm ground clearance lowest point of the car
-r33 has to be 345mm high at the front 355mm at the rear
-no louder than 90 db
-Apparently a front mount and pod is ok if it doesnt go through a structual point of the car and pod is secure (this is what i got defected for induction) which regency say its not even a defect....
- No bleed valve, boost controllers
-Must have standard ECU
-Suspension Bushes mustnt be cracked or damaged
-Hicas lock bar are not allowed cuz its a welded suspension component
If anyone has failed the regency test which i gather isnt hard to do could you please post in hear what you needed to change to get through and we can add to the list. Also the regency inspection is now $132 and roughly a 1-2 week wait to get in. Any info posted in hear could go along way to help out alot of people as alot of people are getting defected lately.
Cheers iLEC
Edited by iLEC
https://www.sau.com.au/forums/topic/195891-been-defected/#findComment-3507913
298 are u for real??
Hicas lock bar engineering is 250 from most automotive engineers on the list at regency.
Now im sad that my gtr is defected, going to cost more then i thought to goto regency :)
Also pods that are secure are fine and FMIC are fine but you cant cut bumper reinforcement.
https://www.sau.com.au/forums/topic/195891-been-defected/#findComment-3507964
So if you cant cut your reo bar, must mean most lines with fmic's are a defect. I dont even have a reo bar because of my 120mm thick intercooler. I was thinking of cutting one to fit but if this is still a defect no use doing it then.
https://www.sau.com.au/forums/topic/195891-been-defected/#findComment-3507968
I didnt think you can engineer your hicas lock bar?
https://www.sau.com.au/forums/topic/195891-been-defected/#findComment-3507972
Also the regency inspection is now $298 and roughly a 2 week wait to get in. Any info posted in hear could go along way to help out alot of people as alot of people are getting defected lately.
Cheers iLEC
its deffently not that much, its between 120-130bux first inspection and 70-80 for second
used to be 76 for the first inspection and like 45 for the second :s
damn government :)
https://www.sau.com.au/forums/topic/195891-been-defected/#findComment-3508100
If anyone has failed the regency test which i gather isnt hard to do could you please post in hear what you needed to change to get through and we can add to the list. Also the regency inspection is now $298 and roughly a 2 week wait to get in. Any info posted in hear could go along way to help out alot of people as alot of people are getting defected lately.
Cheers iLEC
Fantastic idea guys......this is a really good thread that could save other unsuspecting defectees alot of cash and heartache.
So anyone with any experience with Regency and the processes involved to lift the defects need to be listed here.
https://www.sau.com.au/forums/topic/195891-been-defected/#findComment-3508128
I got defected for having a pod filter (which is secure) and for having a front mount intercooler. I rang regency they said it is NOT a defect unless the pod is not secure and if the fmic goes through a structual point of the car(the piping) its a defect which mine did not (cop obviously had no idea what he was on about) and when i rang regency they said it WILL cost $298 for first inspection and i questioned that they said the price went up about 10 months ago. From what i gather the cut reo bar is a definate defect but i have heard if they cant see it they wont pick on it........ i have had to cut mine to fit my fmic and new front bar so still undecided weather or not to change it as they wont be able to see it unless they take my front bar of. So has anyone got any standard 33 gtst series 1 springs i can buy lol.
Cheers iLEC
Edited by iLEC
https://www.sau.com.au/forums/topic/195891-been-defected/#findComment-3508295
hey thats unlucky about a year ago i got defected only cost me 70 bucks,, um what i dont understand is the two things that were defected on your car are two legal things, so how come u didnt question it or do anything about it cause i actually think you would be able to get off this one.
https://www.sau.com.au/forums/topic/195891-been-defected/#findComment-3508353
I did ring up the police station after speaking to regency they said to bring it to your local cop shop and explain the situation and see what happens the only problem is the car is to low and to loud anyway and i have different turbo, ecu, bleedvalve..... so the car is defectable i just didnt get defected on what is actually defectable. So its not gona matter if i bring it to the cop shop cuz there just gona pick on the things thats defectable anyway(fair enough i guess) so im gona raise it and shut it up abit then take it to the cop shop and try my luck but i really think im just wasting my time. It just pisses me off that a coper can defect you when they clearly have no idea what the hell their on about.
https://www.sau.com.au/forums/topic/195891-been-defected/#findComment-3508477
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
