You mean ETC.
Go to your boot and look under the parcel shelf. You'll find 3 units there. The one on the end on the passengers side is the one you want. Thats the ATESSA unit. Unplug everything from it and connect the plugs from the ETC. On the ETC loom there are extra plugs, connect all the units plugs into this.
There will be an extra plug (plus one more that has no purpose) near the ETC that is used for the EDA if you have that.
If your 4WD and ABS lights come on, it means you havent installed it correctly. Just unplug and replug again.
I run mine from my glovebox under the carpet and seats to the boot.
https://www.sau.com.au/forums/topic/200873-hks-ets/#findComment-3573028
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
