  • Replies 110
RIP eyelid - 2004 - 2010. She served me well, stayed on the car at 200kmp/h, never once looked like falling off. Then between home and the carwash at 70kmp/h, she departed this world.
Took an hour to get the other one off and clean all the sikaflex off both headlights. Good as new:
Updated specs while I'm at it:
Engine/Driveline:
- Engineered/VASS certified JDM Avenir PNW10 SR20DET (2L Turbo) conversion from stock GA16DE (1.6L N/A), custom wiring harness, air-con removed.
- Avenir ECU re-mapped by Dr Drift
- Nismo 740cc injectors
- Z32 Airflow Meter with Bosch plug
- Silvia S15 Fuel Pump
- HKS EVC 6 Electronic Boost Controller
- HKS Oil Cap
- Nismo Radiator Cap
- SR20DE engine mounts pressed with solid inserts
- 600x300x76 JustJap Front Mount Intercooler, custom mandrel-bent Stainless Steel piping
- Go Fast Bits StealthFX Plumb-back/Atmo Blow Off Valve (Black) - recirculates to pod box for legal reasons
- Custom Aluminium Pod Box with 3A Racing Pod Filter, Metal Intake Pipe, battery moved elsewhere in engine bay to suit
- GT2860RS turbo (.64 housing) with modified actuator bracket and rod
- Pulsar RNN14 GTi-R Exhaust Manifold
- Longer Manifold Studs
- Liverpool Exhaust 10mm Manifold Spacer
- 3" full Stainless Steel Exhaust, Stainless Steel straight-through Muffler with Droopy Chrome Tip
- CES Split GTi-R Dump Pipe HPC-coated silver
- CES Metal Substrate Catalytic Converter
- Pulsar NX-R manual gearbox completely rebuilt with:
*PAR RS5F32A 1st~4th straight cut synchromesh gearset
*PAR RS5F32 Crown Wheel & Pinion Shaft 4.08 ratio
*GC Corp sprung centre 24 spline clutch kit
*New Differential Bearings
*Nismo 1.5 Way LSD
- Custom Pulsar RNN14 GTi-R & N16 hydraulic clutch conversion
Suspension & Brakes:
- Tein Super Street Coilovers with Pillow-Ball Upper Mounts
- Tein Electronic Damper Force Control (EDFC) on each strut
- Whiteline Blade Adjustable Rear Swaybar
- Whiteline Adjustable Front Strut Brace
- Sentra B14/200sx Adjustable Rear Strut Brace
- Pulsar N15 SSS 28mm Front Swaybar
- Whiteline Front Swaybar D-Bushes
- Whiteline Front Swaybar End-link Bushes
- Whiteline Steering Rack Bushes
- Pulsar RNN14 GTi-R Front Calipers (AD22VF) sprayed gold
- Bendix Advance Brake Pads (front)
- DBA Slotted Rotors (front)
- Pulsar N15 SSS Rear Disc Brake rear axle conversion (calipers sprayed gold)
- Unknown pads and rotors (rear)
- Modified stock Brake Master Cylinder
Body Modifications:
- Pulsar N15 S1 SSS Front Bumper (middle insert cut out for FMIC)
- Topstage S1 Lip
- ASV N15 (VZ-R Copy) Side Skirts
- ASV N15 (VZ-R Copy) Sedan Rear Pods
- JDM Pulsar N15 Lucino Grille
- JDM Pulsar N15 GT Bootlid with high-mount brake light mounted in the spoiler
- De-stickered and de-badged bootlid
- Full respray in custom White with House of Kolor Ice Turquoise Pearl
- Black Bonnet & Grille with House of Kolor Ice Turquoise Pearl
- Colour-coded door handles and mirrors
Interior:
- Pulsar N15 S2 SSS Steering Wheel
- 1Kg Dry Chemical Fire Extinguisher mounted in the passenger foot well
- Defi DIN cluster mounted in DIN spot under Air-Con/Heater Controls, head unit relocated to bottom DIN slot
- Defi Racer Series Boost Gauge mounted to drivers side A-Pillar
- Nismo GT500 urethane shift knob
- Black Recaro-style front reclining racing seats with custom rails
- Back seat & all door cards fully re-trimmed in black mesh material (to match front racing seats)
Wheels & Tyres:
- 16x6.5" RJR Wheels (temporary)
- Yokohama Advan A048 195/50/16 Semi-Slicks (for race)
- Maxxis Victra MA-Z1 205/45/16 (for street)
- Nismo Extended Wheel Studs all round
Lights:
- Pulsar S1 N15 SSS Foglights and Switch
- Pulsar S2 N15 SSS black surround crystal Headlights
- Pulsar S2 N15 SSS Front Indicators
- Pulsar S2 N15 crystal Tail Lights
- Clear Side Indicators
- Phillips Bluevision headlight and parker globes
- Narva Plus 30 foglight globes
Windows:
- 20% tinted rear windscreen, rear quarter windows and rear side windows and 35% (darkest legal) tinted front side windows
Audio Details:
- Clarion DXZ656MP Head Unit
- Pioneer 6" 4 Way Speakers mounted behind stock door pods
- Pioneer 6x9" 3 Way Speakers mounted flush with rear parcel shelf
Other:
- Drivers Airbag
- Viper Paging Alarm with Remote Start
  • 1 month later...
A lesson I learnt a long time ago but ignored - the car is not broken, do not fix it. The car has been driving so nicely on the odd day I've taken it out in the last couple of months.
I ignored my own advice today and thought it might be nice to get the new O2 sensor bung welded in the dump pipe, install the new O2 sensor and fit the remap board to suit the O2 sensor. Remember it hasn't been running a working O2 sensor since the engine conversion in early 2006. I'm now left with a car that's pissing fuel into the cylinders and flooding, misfiring, doesn't want to start, the check engine light is on and if you manage to get it started you have the keep the car in gear and the revs up or it just stalls. It also fills a workshop the size of a school hall completely with fuel smoke in about 5 second.
Happy happy joy joy, happy happy joy :D
The tuner says the check engine light means that the board isn't seated properly inside the ECU, meaning that the ECU is working as a stock ECU and has no compensation for the 740cc injectors and Z32 AFM that are trying to communicate with it. Problem being that we took out and put back in the original board (that it ran perfectly with) and the new board multiple times and it won't run with either board in it, O2 sensor plugged in or not.
I am internally raging. I should have just left it.
That'd mean it also forgot it's tune on the board that I just pulled out and then put back in. I'm thinking there might be an issue with the header it's plugging into as it's not running with either board in it :P Shall investigate next weekend.
  • 3 weeks later...
Okay, so there were two problems. We plugged in the boards one set of pins out. Rectified that and both boards only start the car in limp mode, meaning both boards have lost their tunes. So if that is the only issue then once the board is re-flashed this weekend the car should be apples.
Okay, so sent the ECU off to the tuner, was told I still had the board plugged in wrong. Tune re-flashed onto the board and the board re-installed, ECU back in the car and O2 sensor plugged in. Cars starts perfectly, drives and idles okay but the engine check light started flashing about 2 minutes into the drive. No idea what it is.
