VEEM just quoted me some crazy price.. fair enough it's practically a brand new tailshaft made from 3.25" tube with heavy duty uni's, new centre bearing and a new splined yoke.
Anyone had something like this built?
Carbonfibre tailshaft single piece is $2k to your door from the guys who make the mines ones.
Or a chrome molly one (stong) from UAS is less than $600.
Both save alot of weight over stock. And eliminate the centre bearing.
I dont like the idea of a 1 piece. Obviously nissan didnt either
they have pros and cons of design.
The two bit ones sap power at the bearing, are heavy and the centrebearings are a source of failure under . They are smooth though.
A single chromemolly is lighter and better for performance but, would transfer more vibrations.
A single carbon fibre shaft is lighter again and transfers less vibration than all the above. It is superior in every regard except cost.
Cheap/reliable/fast : pick two applies.
Twincam 3L w/ GT35R.. monster torque.
I took a 32 & 33 tailshaft to veem, they said the uni's are on their last legs and the centre bearing has play (the 32 shaft), $900 to build a new one with heavy duty uni's etc.
Told them to get stuffed, Final Drive is building me the same thing for about $650.
i had final drive build mine for the SR powered R34. They supplied all the parts bar the rear section of the shaft (with out centre bearing) and cost was less $500 from memory. Fitted perfect and never a hint of vibration. Second shaft i have had them make both been sweet.
    • And what is the significance of the Italian word for "reserved"? AFAIK, it means nothing WRT GTRs.
    • There's no way that we can tell what they were for because they are not stock. Somebody had something installed that needed an earth and took it 98% out.
    • Hey SAU,  I pulled my fascia apart to remove my cluster and found these snipped grounded wires, and a black wire off to the side. I was wondering if anyone knew what these were for?  To note: My headunit is not powered and has not been since I purchased the vehicle the cigarette lighter was not hooked up either, unsure if this has anything to do with it?
    • Welcome!  Any pics of the new GTR? You'd be amazed how many people have minimal plans initially. 🤣
    • Hello all I've been lurking around and reading many threads for quite some time, so I figured I may as well join in. I recently picked up a R33 GTR 3 V-SPEC RISERVATA that’s mostly stock. The car has always been a bit of a dream for me, and now I’m slowly starting to plan the next steps — nothing too crazy yet, but I’d like to keep it clean and responsive while pushing a bit more power.
