Hey guys have this cat back exhaust.. havent used it since i got it..
looking for 180 bucks.. add a cheap front pipe and u have a cheap turbo back exhaust
in sa
luke 0414391972
Price Drop 140
Edited by lukew105
https://www.sau.com.au/forums/topic/203017-r32-exhaust/
Hey guys sorry about late reply...
its got one mid muffler and one end muffler
i havent used it because i never got my 32 shell ont he road.. i sold it so i dont need it anymore
anyway
PRICE DROP $140
Ps its a relatively quiet exhaust..
https://www.sau.com.au/forums/topic/203017-r32-exhaust/#findComment-3619279
