hey guys
recently my car has been acting a little funny, I had my car tunned a few months back with a gt3071 740cc power fc etc ec, then decided to rebuild after the tune (stupid i know) this consisted of a port job different compression forges etc etc. Now to the problem, after the engine was rebuild it was sweet never missed a beat sometimes it use to stall if you were in 4th and chucked it in netural but after about 4000kms the car totally changed. I get very bad idle hunt most of the time when i hit the lights ranging from 300 (about to stall) to 1500. and it takes a a good minute to find its true idle. Also now and then the car gets a slight miss just on normal driving and sometimes when you get up it in 1st gear it misses abit.
Ive hardly ever got up it since the rebuild as i want to get it tunned once i get new cams and gears, but these problems are worrying me, any advice would be most appreciated.. This is on a sr20det by the way..
thank you
https://www.sau.com.au/forums/topic/205347-bad-idle-hunt-and-slight-miss/
Theres the issue right there. Maybe u snapped a swing.. sorry "rocker" Maybe the tractor timing chain rattled itself off hahaha *chuckles* jk - cant help myself
Start with cleaning your idle control valve, and removing your atmo bov if present, till you can tune around it.
EDIT You've done 4000kms and haven't loaded it yet? Who suggested that run in program - Hrrrrmmk
Nice 4/5 in your avatar :yes:
Edited by GeeTR
them mafia im giong to be cleaning my icv on wednesday
the afm is a fair distance frmo the turbo and has a few bends 2 of them being 90 degree, im guessing you go through matty spry to say that :)
Also does anyone have any idea how to check for sensor errors on the pfc handset as a few people told me you can check it??
thanks for your help guys most greatfull.
the afm is a fair distance frmo the turbo and has a few bends 2 of them being 90 degree, im guessing you go through matty spry to say that :cool:
Definately dont go throught MAtt Spry but I do know that big AFM's on SR's can cause reversion issues.
The ICV isn't going to cause a missfire.
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
