Item: 1992 Diahatsu Charade 4 door white gl
Website:
Item Condition: excellant
Reason for Selling: its my second car and its not getting driven
Price and Payment Conditions: $3,500 ono
Extra Info: four cylinder automatic, air conditioning, interior in excellant condition, 4 good tyres, 183,000 k's was an old lady's car traded into my work that i bought as a cheap get around. vehicle has been recently serviced and is registered until july 2008. rwc will be supplied. fuel miser will get close to 700 klms on a tank of fuel on the highway (35lt tank)
Pictures: sorry no pics. car is extemely good condtion for its age and drives like brand new
Contact Details: shauno 0424534691 or 54403613 during work hours
https://www.sau.com.au/forums/topic/205990-diahatsu-charade/
Website:
For what it's worth, my mate has one of these with over 300ks on it and has never had a major problem. He's waiting for it to die so he can get something better, but it simply won't.
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
