hey im just purchase either a GT-RS or 2530 for my 20det... i currently run gtr cooler, pod, zorst, eboost and pfc...
im getting z32, gtr injectors to go with it...
just wondering on which turbo i should go for! looking for the best power with best response!
any opinions??
and i have looked in the 20 mod thread but not many results for these two turbos!!
cheers adrian
https://www.sau.com.au/forums/topic/208435-to-gt-rs-or-2530/
i would be going the HKS 2530. You will hit boost early and have it going through the rev range.
i would only suggest the GT-RS on a mildly to built engine.
NightCrawler on here has the 2530 on a RB25 and he likes it.
Ive heard a few people who have had the 2530 say they weren't happy with it at all, Was why I went for a Trust TD06.
With a 2530 you're limited to 230-240 kw's at the most, if you get greedy and want more, you'll have to go bigger, like the GTRS/SS...
Decide how much power you want, how much lag is acceptable to you, your budget, and what you intend to do with the car, and go from there.
Drift/Hills/Good response/230 kw's at the wheels max = 2530
Straight line duties/higher speed drifting/dyno bitch/more lag but potentially more power = GTRS
Edited by R31 drift pig
yep I love my HKS 2530 - makes an easy 230rwkw with standard injectors, auto trans, and an Apexi SAFCII - would make much more with a PowerFC and manual trans. Add cams and would make even more. Response is awesome - starts building boost around 2,000rpm and builds very nicely from there .... worst thing in any street car is to have lag, lag, lag, then whack the power comes on hard and strong IMHO.
I have a 2530 on my car. Some people say they have same lag or less than a 25 stock turbo, but that is not true.
I love this turbo on my 20, however, is not as responsive as I would have liked (drifter).......I suppose you cant get enough response on a drifter :D,...but having said that, its very good for the street imo.
Mine puts out 230kw, I haven't tried the GT-RS, but I can tell you you wont be disappointed with the 2530 :P
If you are looking for about 220-240kw then look no further.
Cheers
Ric
Edited by Richo
What setup do you have richo? Fuel pump/injectors/afm/ecu/FMIC/Gearbox etc. What rev limit do yoy have too?
I spoke to ryan at kansai, who said that himself and huddy were not happy with the 2530's at all.
Both cars were using stock cams and plenums as well.
Im hoping the TD06 I bought will be on full boost by 4000 - 4200, and with a 8500rpm limit, still a very usable powerband, provided I can keep it on boost LOL
Bosch FP
GTR injectors
TSL ECU
Stock:
AFM
Gearbox
Cams
Plenum
HKS Cast Low mount manifold
HKS External Wastegate
I hit full boost at around 4000 - 4100 all the way to the limiter @ 8500rpm :D
If you want something more responsive in an RB20 you need to go smaller, a 2510 would be perfect but then again it wont give you 230kw, so it depends on the individual really.
Cheers
Ric
so does anyone know when fullboost hits on each of these turbos?
and wat would a gtrs be able to make...
coz if full boost is a matter of 500rpm but the gtrs make shit load more power then that would be the way to go?
cheers
The GT-RS wont make a shitload more power, maybe another 20rwkw. It uses the same turbine as the 2530, which is what's holding it back.
GT-RS is pretty much a 400hp compressor and 300hp turbine. Not much point in getting more air in if you can't get more out is there? If you don't track your car, I see little to no point in going the bigger turbo.
I still believe the GCG highflow is great turbo for the RB20. I made 220rwkw on 1.4bar on the old clapped out RB20 that popped a couple of weeks later. I made 1.4 bar by about 3700rpm which is freakin awesome response for an RB20. I believe if the motor wasn't about to blow, it would've made more power.
Oi Showza! where have you been dude?
Did you get your car sorted? Cant wait to see the finish product :)
Ric
^^^ full boost at 4,000rpm that the guys say above sucks ass for the street. My 2530 is making full boost by around 3,000rpm - you really don't want to have to rev the crap out of your car every day on the street to have a bit of fun. The low down torque on my RB25 absolutely kicks ass from about 2,000rpm - awesome from the street!
^^^^ good for you mate!.....We are happy for you.
The question here was aimed at RB20 not RB25.
We all know how responsive a 25 could be with a 2530. :thumbsup: . I dont think the question was "what engine should I run my 2530 with?"
Cheers
Ric
Edited by Richo
It would deffinately be on fullboost later than the 2530 or GT-RS but from all accounts the party should be well underway by late 3000rpm early 4000rpm
Either way if your interested let me know or just check out the link in my sig.
2835 ProS (same CHRA Garrett GT3071R) has the same compressor as the GT-RS, only difference is the turbine is slightly bigger, runs a cropped 56.5mm GT30 turbine compared to the 53.8mm GT28 turbine. It will be laggier, but should be good for a heap more power. Simon Michelmore is running a Garrett GT3071R on his RB25 and making 270rwkw...
Once again, I wouldn't be going the bigger out of those turbos unless you plan on taking the car to the track.
Ric: Just dropped all the engine bits down to the machinist, getting it all machined up now, so car should be driving in 2-3 weeks time I reckon.
Edited by salad
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
