hey!
I have a bit of a hypothetical question for a few cluey engine gurus
i am planning a trip to look at a a car (r32gtr) over 3000 kms away.
Now after pumping this guy for as much info on the phone as i can this is what i have managed to get out of the convo
the car has some sought of vapor coming out of it on down changes which the owner says he has been told the cat is buggered after he took it into get a new cannon put on it and that its whats causing it to blow smoke etc on a down change
he tells me that he reset the PFC back to base map because the engine was detonating after the exhaust mod which i would assume the car is running rough/Rich...
does a worn out cat (original or 14 year old Approx) make exhaust vapor/Dust on a down change or is there something maybe wrong elsewhere in the engine ?
the strange thing is that he only reset the pfc after the exhaust change so i am thinking its not fuel coming out of the exhaust as the exhaust place was the one that told him his cat was buggered and this maybe the cause of the mysterious gas/dust/fuel/oil comong from the exhaust pipe...
Could someone help me out on what maybe going on with this...
he is fairly sure its not blue smoke but in saying that he dosent understand engines to well either
thanks Dj
Edited by ish
Those vapours could be from an ATMO or hybrid BOV on a down change. At high rpm a blocked cat can cause a leak b/n flanges
Sounds ok, increase in breathing hence running richer thus noticably more smoke. Without a tune it would run rough, if not stall with the ATMO unless compensated for with the PFC. Not sure about the detonation, maybe it has something to do with the missing air that the atmo releases and the sys. cant meter
LOTS AND LOTS OF SMOKE. FILLS UP THE CABIN, CANT BREATH, PINK SMOKE BLUE SMOKE YELLO SMOKE AND SMOKE SMOKE.. :-P
Pretty sure All skylines pump a bit of smoke out if they have not been drivin in a long period of time.. gotta remember its a 18 year old car..
CHEEEEEEEEEEEEEEEEEEEEERS
could be the pcv valve sucking excessive blowby in when the car decelerates and engine inlet manifold vacuum is high. pcv valve is closed under boost.
otherwise if the car is cold and has atmo bov, could be dumping fuel in on decel because of the unmetered air exiting the bov, when its hot it should fuel cut altogether (turn off injectors) on decel so you shouldn't get fuel smoke from atmo bov.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
    • That could easily make a horrible noise. +1 to the benefits of: a) Disclosing all relevant information when asking questions such as these, b) Actually going out and having a look at your own car, seeing as you're the one there, and we're not!
