Item: R33 GTS headlights ( both sides)
Condition: good, no broken brackets or fogging
Price:SOLDTo Fit: (What car) R33
Contact: pm or email [email protected]
Comments: Pics will be supplied for interested persons you all know what they look like .
Edited by wrxhoon
https://www.sau.com.au/forums/topic/210590-sold/
Am interested in these headlights.
I have a 03/94 R33 GTS, will these headlights fit onto my car?
If so then I will probably take them off you hands.
Sold subject to pick up and payment tomorrow.
These are series I gts and will fit all series I 33 coupes up to the end of 95 , they will not fit series II gts
https://www.sau.com.au/forums/topic/210590-sold/#findComment-3729895
PM me if the sale goes through
https://www.sau.com.au/forums/topic/210590-sold/#findComment-3731293
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
