Item: rb20det
Website:
Item Condition: good runnin in car still dont know km's
Reason for Selling: buildin 25/30
Price and Payment Conditions: 800 or make offer
Extra Info: motor still in can come look if wanted pm me as i work big hrs n will reply when i get home
Pictures: if wanted
Contact Details:
guys seelin the old rb20 everything on motor but not sellin wit turbo or manifold no loom n no box as will b using them so make offer n feel free 2 come listen or wat ever if u want it
https://www.sau.com.au/forums/topic/211142-rb20det/
Item: rb20det
Website:
Pictures: if wanted
Contact Details:
I JUST WANT TO KNOW IF IT IS A 4WD MOTOR
https://www.sau.com.au/forums/topic/211142-rb20det/#findComment-3742595
  • 1 month later...
