Guys,
Did a search, but still abit baffled, im used to working with non powersteering box's insted of racks.....
The ceff is getting a new rack out of a s13,
Pulled the old rack out and its a hicas rack, with 3 fittings. the s13 has only 2.
Is there a way of fitting it without pulling all the hicas rubbish out? or would just swapping to s13 PS lines and resivoiur be easier and better working?
car has a non hicas rear cradle in it and no lines for the rear
Any help would be great :glare:
Edited by works 510
https://www.sau.com.au/forums/topic/212873-hicas-and-s13-steering-rack/
The hicas front rack should have 2 fittings, an inlet and outlet. And should have a separate connection block bolted on near the steering column shaft. This connection block is simply a point for the rear hicas lines to join the front hicas lines and is completely separate from the front steering system.
I'd recommend just removing any left over hicas stuff, you dont need to swap to a non hicas pump/reservoir, just plumb the outlet from the pump straight into the reservoir inlet.
Ah I see,
My rack had 3 fittings coming out of it :S
I wasnt too sure after the search last nite, and had to get it running (its still not going ffs) cracked the shits and pulled everything hicas out of it. all lines came out. hicas block/solendoid whatever it is near the drivers side strut tower and the resivour.
In went a s13 sr20 resivour, a ca18 s13 line to the pump, and sr20 s13 line to the resi. Rack is also sr20 s13
what a pain
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
