as above..
I don't like the aftermarket one that came with the car.
Just prefer a stock series 1 steering wheel.
I can even swap for the one that is in my car with boss kit too if someone is interested (can get pics if anyone is interested.)
Don't want any tears on the wheel.. I know it's rare but there must be some around.
thanks
https://www.sau.com.au/forums/topic/213108-wtb-stock-series-1-steering-wheel/
this is why I want to swap/replace..
if this is what someone is interested in then by all means.. lets swap.
no shit.. so you got one you want to sell or swap for this masterpiece-o-shit?
afraid not I like my stock steering wheel. Its starting to look a little worn out though. Anyone know if they can be re-trimmed?
this is the wheel
http://www.skylinesaustralia.com/forums/in...t&id=129387
pass on your one thanks
$80 firm + post or you are welcome to pickup.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
