Item:Brand New Viper (791xv) 2-way Car Security System $450 Delivered, TOP OF THE RANGE
Condition: Brand New In the Box
Price: $450 Delivered Anywhere In Australia
Contact: 0433950285
Comments:
I bought this with the intention of installing the top of the range viper alarm into my car, but priorities have changed. My loss you gain. The item is brand new, still in the box. Fits any make and model and is a must for any car.
Here is some information on the unit:
2-Way Remote Start and Security System
The first FCC-legal 2-Way Remote with 66-Bit Clone-Safe Code-Hopping
Full featured vehicle protection and starts your engine with the push of a button
Confirms all commands with easy-to-understand icons with text
Alerts you to security system alarm events by beeping or vibrating when the system is triggered
Lets you keep track of vehicle status
State-of-the-Art Remote Transceiver with Responder Technology:
Optimum Range and Reliability
Bright, Easy-to-Read LCD Screen
Vibrate Mode
23 Different Icon/Text Message
Super bright blue LED light
Belt clip for remote
Remote Start* Features:
Remote Start Convenience
Safety Shut Down
Timer Mode
Complete Engine Monitoring
Anti-Grind
Engine Checking
High-Capacity Relay Satellite
Tach/Voltage Checking
Security Features:
High-Output Mini Neo Siren
Failsafe® Starter Kill
Forced Passive Arming
Active/Passive Arming
Progressive Door Trigger
DoubleGuard® Shock Sensor
Clone-Safe® Super Code Hopping 266 Codes
Nuisance Prevention® Circuitry (NPC)
LED Status Indicator
Ignition Controlled Door Locks
Soft Chirp
Secondary Warning Zone
Remote Controlled Valet® Mode
Bitwriter® Compatible
Parking Light Flash
Clone-Safe
Edited by philmak
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
