R33 Front Rotors $50, Electronic Boost Controller $30, R33 Seats $150, Z32 Afm Plugs $20, Rb Actuator, Freebies
Selling the following items to clear out garage:
Item: Pair of R33 Front Rotors in excellent condition heaps of meat left as shown in pic with only a little even wear since new. Measured thickness which is at 29.1 and 29.2mm so not even half worn. Fits R33 Caliper equiped vehicles
Price: $80 pair Now $50 pair
Boost Controller - electronically activated boost controller valve allowing you to run stock boost and then at the flick of a switch run the boost level you set on the valve. Needs a switch as the one I used for this is still mounted on my console and too difficult too remove again :)
Price: $60 $30
Z32 AFM Plugs + ~30cm of loom ready to splice or wire into your loom to run Z32 AFM. Come complete with instructions on wiring into SR, CA & RB Powered Vehicles
Price - $30 Delivered or $20 pickup
Pair of R33 Front Seats in excellent condition. The drivers seat has a small tear in bolster nothing major. This is the comfy plush velour type model with the adjustable side bolster wings for more support through corners etc.
Price - $150
R33 Stock Actuator in excellent condition to suit R32/R33 turbos
Price - $25 $20
Aftermarket Swaybars
S14 Front 27mm hollow swaybar, same thickness as whiteline HD but a hell of a lot lighter, painted black complete with D bushes, saddles and end links. Hollow bars are generally how the japs make their aftermarket swaybars as they perform the same as solid but save weight which also increases handling. Unsure if it fits S13/S15 Price - $100ono
Stock Sway Bars - $25 each
R33 Front Stock complete with D bushes and saddles but no endlinks
R33 Rear Stock complete with D bushes but no saddles or endlinks
S13 Rear Stock complete with D bushes but no saddles or endlinks
Freebies
Pair R33 Front Castor Rod Chassis Mounts
Pair S13 Rear 4 Stud Hubs
Adelaide but will post some items at your expense
Contact:
SMS 0404998591 or PM prefer SMS
Edited by nigelswazi
    • bumping this post as im still having dramas, my fuel pick up is sitting on the bottom of the tank, my pump gets a constant 13 volts through a relay, my fuel pressure holds consistently without fluttering or dropping, yet as soon as im near half a tank of fuel my car starts fuel starving and leaning out, it cant be due to g force as it never pulls hard enough before it starts breaking up, any help would be much appreciated
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
