Item: Power FC with commander and 2x Z32 afms and 2x Apexi Power intake filters to suit R32/33 Rb26dett
Age: 18 months
Condition: As new
To Fit: (What car) 32/33 GTR
Contact: via PM or email only!!
Power FC to suit R32/33 GTR. Comes with commander, 2x Z32 afm's with plugs, 2x Apexi Power intake filters- All Bought new 18 months ago.
Currently tuned with 850cc injectors producing 420hp@1 bar on a built engine.
We all know that Power FC's are usually around $1k to buy new. New AFM's are around $400 each plus a plugs. New apexi power intake filters are around $100+ each. So $2000+ worth of goodies for $1800.
Serious buyers only
$1800
-will not separate-
pics will be emailed to those who ask via PM or EMAIL. Although we all know what a power FC/ commander, Z32's and Apexi pods look like.
Pods and filters can be seen in pic attached.
Located in Bunbury WA
Freight at Buyers cost.
All will be sent in the boxes they were originally bought in.
PM or email [email protected]
-cms-
Edited by CMS Drifter
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
