HI GUYS,
I am having problems with my hicas light.
The light turns on about half an hour of driving and the back
wheel kicks out.
If i turn the car off then on again the light goes out.
The car is a 1993 R32 Gts4t.
Has anyone ever had this problem before i have taken the
car to several mechanics and no one has been able to
fix the problem.
Any suggestions will be greatly appreciated.......
https://www.sau.com.au/forums/topic/21788-hicas/
Hey Enrico,
We have found the problem when you put your steering wheel on make sure it is perfectly straight and the hicas sensor is in the right place.
what happens is when you have been driving for over 20 minutes the computer senses that you cannot be turning all that time and has a dummy spit the arse end kicks out and light comes on.
I had been to many mechanics here in sydney and none of them
knew what they were doing some supposed import specialists.....
Try this and let me know how you go.
Regards,
Daniel
https://www.sau.com.au/forums/topic/21788-hicas/#findComment-477187
I am not sure about where the dead centre is i have tried to get the wheels as straight as i can and re fit the wheel.
No luck its still a bit off centre i will try moving the wheel i notch
again tomorrow.
If that doesn't work i am going to Unique Auto Sports on saturday for a service i might get them to have a look into it and
see if there is something i am overlooking......
https://www.sau.com.au/forums/topic/21788-hicas/#findComment-482053
OK
There was something i overlooked.
ON the rod where the wheel fits onto has got a mark on it and geuss what i am 99% sure that this is the top dead centre mark.
Also on the standard wheel there is a mark on the top centre....
How stupid of me to overlook that i must have been drunk.
Hopefully this fixes my problem and more importantly helps someone else.
With the aftermarket wheels make sure you have a hicas boss kit with any luck they will have a mark top centre aswell and so they should at around $250AU ea.
I haven't seen one as of yet i am on a pretty tight budget and would rather do some performance mods than anything else.
Well thats enough crapping on from me i will be updating again tommorrow night with how it goes need to go on a freeway to test it out properly...
https://www.sau.com.au/forums/topic/21788-hicas/#findComment-484017
Well i re-positioned my steering wheel today, and the light hasnt come on since so lets hope its all goot now!. However a funny thing hapened when i was driving home. I turned on my hi beams, and for a split second the Hicas light turned on, then turned off. Wierd. the globe hasnt blown thou.... Anyone have any ideas??
https://www.sau.com.au/forums/topic/21788-hicas/#findComment-487577
Well im pissed off still not workin dont know what to do now.
I had the car serviced today and have been told that the front end bushes are F**KED and they will need replaceing.
Dont know if this could be contributing to the problem.
Might have to take it back to UAS and get them to have a look at it for me.
Dan
https://www.sau.com.au/forums/topic/21788-hicas/#findComment-488216
I have a '93 GTS-4 and I am also having a problem (I think) with my HICAS, my light stays off while I am driving and all that, the fluid levels are all full but the back end seems to be kicking about now and then, especially when I go over high gaps in tarmac (like at the start of different surfaces with dodgy roadwork and bridges).
Does anyone know what might be the problem?
https://www.sau.com.au/forums/topic/21788-hicas/#findComment-488505
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
