  • Replies 473
GOLD Mr.LUKE
H___ <--insert letter here haha
bye bye bye bye bye bye bye bye bye bye bye bye
hahahaha
this is what i think of bunny->
http://www.youtube.com/watch?v=OGQTAW878ZM
ahahahahaha im a cruel bastard ahahahaha
its funny some of them though
SERIOUSLY I DONT THINK THATS FUNNY AT ALL
your age is showing nathan anyone that thinks thats funny is an idiot as getting an animal to kill another animal for fun is F*&%ed up and stupid!
1,2,3 FIGHT!! jokes jokes
Nathan i think you should say sorry, i think kellie is mad at you...
Looks like you're in the shits dude.
Its natural that snakes kill other animals, but exhibiting it for personal amusement is wrong. :ermm:
woopsies lol
nah its just a joke, wasnt aimed at any personal attacks
just bored at work, there is one where a bunny beats the snake but yeah.
ummm yeh i kno wen i should not show up for a long time haha
skip to 3min in
its so stupid its funny
watch out JDM032 cause when those bunny's attack ud best hope you can run like the tortoise :)
i can see ya were trying to be funny but it was a lil untasteful if there is such a word
Edited by Inline 6
ok i study at urrbrae and we were building a retaining wall in the wetlands off crossroads... to get to the wetlands we cross a paddock of about 6 sheep.. at the end of the day walking through thte paddock i thought it would be amusing to chase the sheep(showing my age here) i cornered them and wont jumped right into the fence.... i got flamed, abused and half my class hates me now(oh well only 5 more weeks) but it was funny... they get treated worse when they are sheered.... i felt like an idot after....
there is my rant
walked all the way to the regestra yesterday to just confirm the date i get my liscence back! yes it is 13 days from today..... WOW!
anyone going to unified(gig down at flinders) tonight???
Attention Kell, Steve or anyone for that matter ...
New member going by the name of Dazza88 who is enquiring about cruises and meeting spots is a suspected cop. :(
No posts, no personal details, no profile details.
Clearly they haven't worked out the difference in "car hoons" and "car enthusiasts" ... we're just wallets on wheels to them regardless. :down:
If you get a PM like I did, send them to some Commonwhore cruise :thumbsup:
Edited by RubyRS4
Thanks for that information Reuben....
there is my rant
lol. electric fence?
im sure if they have a read through this forum, they will realise we DO NOT tolerate Hoon driving.
just sucks they are going to this extent to keep an eye on us.
maybe a sticky thread addressed to the sapol explaining what we are about is an idea? MODS?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
