Nissan skyline r33 gts-t series 2
87,213kms
color White
fully complied yes
currently registered till 2009 jan
Very clean car inside and out .
Rb26/30 engine with forged pistons(arias) and conrods.(gillet) Rebulit by 8mnths ago
motec m4 clubsman
550cc injectors
standard fuel pump
4speed manualised auto from 300zxTT
gt35/40 turbo
hks front mount intercooler
gtr plenum
custom exhaust manifold(low mount)
turbosmart dual boost controller with turbosmart progate wastegate
3inch exhaust from turbo back with double muffler and cat
19inch impule white rims brand new tyres
Making currently 193rkw @ 8 psi but capable of 370rwkw with current set up.
Everything done to this car was done by a reputable workshop.
Reason for selling going overseas. I love my baby regretful sale. $23,000
