This car is in perfect condition, come with alot of extra new parts on it. Anyone who are interested, can gave me a buzz on my contact number for serious buyer only. Pls dont waste my time ask me send some more pic of it. Price can be negotiable without some of the new parts and new wheels coming with it, so can make me a offer for serious buyer. Im willing to swap with a stock car 4 doors and cash my way, as im doing another project car so dont need another performance car.
Make: NISSAN
Model: SKYLINE GTR 34 VSP3C 2
Milage: Lest then 30000km
Transmission: 6 speed Getrad
Colour: White
Complied? Yes
RWC supplied? Yes
Currently registered? PERTH
Price: $93000
Contact: 0424444439
Comments / Modifications: The engine internals are stock.
LinkS: CarSaLeS GTR 34 VSP3C 2
Images:
Edited by Hoshima
Price drop without some of the parts $87500 neg, anyone who got cash ready can make me a offer. I may consider it :wave:
Edited by Hoshima
Price drop $85k or nearless offer i may consider it. The car will come with stock wheels now and some of the new parts wont come with the car as well depends on the price who offer me :(
Bump , im sure most of us can only dream for now.
Hey can i ask a quick question, the wing on the back is that standard height or is that the higher version ?
looks so nice
bump
bump
Back for sale, as the guy cant be able to get hold with the money at the moment. Any offer i may consider around 80k now. Make a offer if anyone interested. As i need a space for my other car in my garage. Some of the new parts going to be removed from the car and come with stock wheels now. The engine will be still the same :)
Edited by Hoshima
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
