Item:
Turbo from RB25DET engine
48,000 kms
Condition:
Very good condition. Minimal shaft play.
Price:
$250
To Fit: (What car)
RB25 or RB20
Any T3 flange manifold
Adelaide SA
Contact:
Ruby via PM first. I'll give you my mobile number when I know you're serious.
Comments:
Just came out of car.
https://www.sau.com.au/forums/topic/225300-rb25det-turbo/
Turbo not for sale anymore.
I'm keeping it ... might just use it for a paperweight. Can't be bothered selling it now to no-shows. :(
Edited by RubyRS4
https://www.sau.com.au/forums/topic/225300-rb25det-turbo/#findComment-3979021
  • 4 weeks later...
I'm keeping it ... might just use it for a paperweight. Can't be bothered selling it now to no-shows. :devil:
Hey mate, just wondering if you've changed your mind about selling the turbo, if your keen to sell it let me know...
https://www.sau.com.au/forums/topic/225300-rb25det-turbo/#findComment-4039127
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
