Group Buy: 60mm Ams Gauges + Shadow Gauges (new)
This Group Buy will ends on 20th July 2008 (Sunday)
My trader feedback: http://www.skylinesaustralia.com/forums/in...=35717&la=0
I have got a mate working in www.espadaperformance.com. And thus, I have gotten you guys a very good price on the gauges. Therefore, I post it up here, hoping to share this great deals with you guys.
the product offer is AMS 60mm Gauges. You guys can check what's the RRP of these gauges from the website.
This group buy will just be series 2 gauges as series 1 gauges have been cleared.
Series 2 will cost $60.
Gauge Cover will cost $2.
Water and Oil adaptor will cost $20.
Fitting mount will be included in the box when you buy a gauge.
Payment preferred: Bank Transfer.
Delivery & Conditions of Delivery: courier interstate only.
Product features:
2.5" STEPPER MOTOR GAUGE
• Provides smooth operation • Very exact
• High precision & quick response • Bright LED illumination
• Precise electrical sensor • Does not require any Control Unit for use
Series 2:
Stepping motor provides smooth operation
Ignition ON initiates self-luminescence gauge
Lightning-like Opening / Closing mode
Example of Opening
Adjustable warning setting
Self-diagnostics function monitors both sensor disconnection and short-circuiting during startup
a) Sensor disconnection check
This function reports any improper connections, broken or disconnected sensor or sensor
wire. The pointer will wave between 250 and 260 degrees.
b) Short-circuiting check
This function indicates any short circuit on the sensor or sensor wire.
The pointer will wave between 10 and 20 degrees.
Using High-brightness LEDs Illumination
Illumination color can be chosen from white, amber ,red, green and blue
Product List:
TACHO 0-10,000RPM
BOOST PRESSURE BAR
WATER TEMP 50-120℃
OIL TEMP 60-150℃
OIL PRESSURE 0-7kg/cm2
VACUUM 0–30 in.hg
VOLTAGE 8-16VOLT
INTAKE.TEMP 20-120℃
A/F RATIO LEAN-STOICH-RICH
Please note that the A/F Ratio gauge comes only in Silver watchcase.
Note: You guys can choose between silver or black watchcase for the series 2 gauges (except A/F Ratio, which only comes in Silver watchcase).
NOTE:
For those who are interested, please let me know:
- what gauge you're interested in
- your color choice for series 2 (Black or White watchcase)
- Your LED light choice
Espadaperformance has start selling a higher quality range of gauges brand called "Shadow"
I just post it together to see anyone is interested in this range.
You can go to the website to read more on this gauge range.
there are 3 broad models:
1st Picture above is SMOKE FACE WHITE LIGHT
2nd Picture above is CLEAR FACE WHITE LIGHT (White)
3rd Picture above is CLEAR FACE WHITE LIGHT (Black)
Picture 1 and Picture 3 has a choice between 52mm or 60mm whereas Picture 2 comes only in 60mm
I was shocked to see that the gauges is only 3cm thick!!!!!
Anyway, you have a choice of a gauge cup holder or the gauge ring holder.
A picture of the gauge can be seen here:
Product List:
- Water Temp
- Oil Temp
- Oil Press
- Turbo
- Voltage
- Intake Manifold Press
Please note that the Exhaust Temp gauge are currently out of stock.
The best price I could get for this gauges is $150 each
Shadow Water Adaptor will cost $30 (choice of 28mm, 30mm, 32mm, 34mm, 36mm, 38mm, 40mm)
Shadow Oil Temp Adaptor will cost $30
Both Adaptors have a choice of colors - Blue, Silver, Grey
You guys are given a choice between these 2 brands.
If you're interested in this brand,
please tell me:
- what gauge you want
- your choice out of the 3 models - Smoke, Clear Black or Clear White
- tell me your preferred gauge size - 52mm or 60mm (for the 2 models)
- if you're also buying the adaptors, choice of dimension for water adaptor is needed and your color choice.
- tell me you prefer a cup holder or the ring holder.
Will start taking orders from now till 20th July 2008.
not missing out on this one lol
oka i would like:
1x Series 2 Boost guage, Black watch case and White LEDs (if you can get the boost guage in PSI that would be awsome)
1x Series 2 Oil Temp Guage, Black Watch case and White LEDs
1x Oil Temp adaptor thingy
cheers
oka i would like:
cheers
Sure thing mate. :D
but i'm sad to tell you that boost gauge comes only in bar. are you still interested?
Cheers.
Sure thing mate. :D
Cheers.
ahh k yer thats cool man still intereested
cheers
hi mate,
- can u get the boost gauge that reading in psi ?
- shadow gauges in 52mm are the same $$ as 60mm ? can u get any other colour light ?
cheers
Ford
Shadow gauges: 52mm are the same as 60mm.
there are only 3 variations for shadow gauges. so sorry about that. but there are good gauges, from the desriptions and the information.
the boost AMS boost gauge; it is hard to get PSI reading. because they have no more stock.
if you're really interested let me know, i'll see what i can do and enquire for you and get back to you.
im assuming it doesnt have a peak warning function ?or does it ?
there are 3 cm thick only. haha...
both gauges have peak warning function.
but shadow ones allow you to set it.
take a look at the website for more info. :)
Hi mate,
I'm very keen on the AMS boost gauge in PSI
cheers
take a look at the website for more info. :P
I did
and it says
Features
• Stepping motor provides smooth operation
• Ignition ON initiates self-luminescence gauge
• Lightning-like Opening/Closing mode
• Adjustable warning setting
• Self-diagnostics function monitors both sensor disconnection and short-circuiting during startup.
• Using High-brightness LEDs illumination and color can be chosen from whiter, amber, red,
green and blue.
so are these different ? or can the warning setting be adjusted?
I did
and it says
Features
green and blue.
Hey mate,
they are adjustable. you have to read the manual after you buy them and you'll know how to do it. :blink:
Cheers. :)
hey mate u reckon u could get a pick of the cup holder and the ring holder..just wanna see which 1 id prefer
cheers
hey mate,
the choice for cup holder and ring holder is for shadow gauges only.
AMS gauges comes in ring holders only.
Cheers. :D
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
