Group Buy: 60mm Ams Gauges + Shadow Gauges (new)
This Group Buy will ends on 20th July 2008 (Sunday)
My trader feedback: http://www.skylinesaustralia.com/forums/in...=35717&la=0
I have got a mate working in www.espadaperformance.com. And thus, I have gotten you guys a very good price on the gauges. Therefore, I post it up here, hoping to share this great deals with you guys.
the product offer is AMS 60mm Gauges. You guys can check what's the RRP of these gauges from the website.
This group buy will just be series 2 gauges as series 1 gauges have been cleared.
Series 2 will cost $60.
Gauge Cover will cost $2.
Water and Oil adaptor will cost $20.
Fitting mount will be included in the box when you buy a gauge.
Payment preferred: Bank Transfer.
Delivery & Conditions of Delivery: courier interstate only.
Product features:
2.5" STEPPER MOTOR GAUGE
• Provides smooth operation • Very exact
• High precision & quick response • Bright LED illumination
• Precise electrical sensor • Does not require any Control Unit for use
Series 2:
Stepping motor provides smooth operation
Ignition ON initiates self-luminescence gauge
Lightning-like Opening / Closing mode
Example of Opening
Adjustable warning setting
Self-diagnostics function monitors both sensor disconnection and short-circuiting during startup
a) Sensor disconnection check
This function reports any improper connections, broken or disconnected sensor or sensor
wire. The pointer will wave between 250 and 260 degrees.
b) Short-circuiting check
This function indicates any short circuit on the sensor or sensor wire.
The pointer will wave between 10 and 20 degrees.
Using High-brightness LEDs Illumination
Illumination color can be chosen from white, amber ,red, green and blue
Product List:
TACHO 0-10,000RPM
BOOST PRESSURE BAR
WATER TEMP 50-120℃
OIL TEMP 60-150℃
OIL PRESSURE 0-7kg/cm2
VACUUM 0–30 in.hg
VOLTAGE 8-16VOLT
INTAKE.TEMP 20-120℃
A/F RATIO LEAN-STOICH-RICH
Please note that the A/F Ratio gauge comes only in Silver watchcase.
Note: You guys can choose between silver or black watchcase for the series 2 gauges (except A/F Ratio, which only comes in Silver watchcase).
NOTE:
For those who are interested, please let me know:
- what gauge you're interested in
- your color choice for series 2 (Black or White watchcase)
- Your LED light choice
Espadaperformance has start selling a higher quality range of gauges brand called "Shadow"
I just post it together to see anyone is interested in this range.
You can go to the website to read more on this gauge range.
there are 3 broad models:
1st Picture above is SMOKE FACE WHITE LIGHT
2nd Picture above is CLEAR FACE WHITE LIGHT (White)
3rd Picture above is CLEAR FACE WHITE LIGHT (Black)
Picture 1 and Picture 3 has a choice between 52mm or 60mm whereas Picture 2 comes only in 60mm
I was shocked to see that the gauges is only 3cm thick!!!!!
Anyway, you have a choice of a gauge cup holder or the gauge ring holder.
A picture of the gauge can be seen here:
Product List:
- Water Temp
- Oil Temp
- Oil Press
- Turbo
- Voltage
- Intake Manifold Press
Please note that the Exhaust Temp gauge are currently out of stock.
The best price I could get for this gauges is $150 each
Shadow Water Adaptor will cost $30 (choice of 28mm, 30mm, 32mm, 34mm, 36mm, 38mm, 40mm)
Shadow Oil Temp Adaptor will cost $30
Both Adaptors have a choice of colors - Blue, Silver, Grey
You guys are given a choice between these 2 brands.
If you're interested in this brand,
please tell me:
- what gauge you want
- your choice out of the 3 models - Smoke, Clear Black or Clear White
- tell me your preferred gauge size - 52mm or 60mm (for the 2 models)
- if you're also buying the adaptors, choice of dimension for water adaptor is needed and your color choice.
- tell me you prefer a cup holder or the ring holder.
Will start taking orders from now till 20th July 2008.
not missing out on this one lol
oka i would like:
1x Series 2 Boost guage, Black watch case and White LEDs (if you can get the boost guage in PSI that would be awsome)
1x Series 2 Oil Temp Guage, Black Watch case and White LEDs
1x Oil Temp adaptor thingy
cheers
oka i would like:
cheers
Sure thing mate. :D
but i'm sad to tell you that boost gauge comes only in bar. are you still interested?
Cheers.
Sure thing mate. :D
Cheers.
ahh k yer thats cool man still intereested
cheers
hi mate,
- can u get the boost gauge that reading in psi ?
- shadow gauges in 52mm are the same $$ as 60mm ? can u get any other colour light ?
cheers
Ford
Shadow gauges: 52mm are the same as 60mm.
there are only 3 variations for shadow gauges. so sorry about that. but there are good gauges, from the desriptions and the information.
the boost AMS boost gauge; it is hard to get PSI reading. because they have no more stock.
if you're really interested let me know, i'll see what i can do and enquire for you and get back to you.
im assuming it doesnt have a peak warning function ?or does it ?
there are 3 cm thick only. haha...
both gauges have peak warning function.
but shadow ones allow you to set it.
take a look at the website for more info. :)
Hi mate,
I'm very keen on the AMS boost gauge in PSI
cheers
take a look at the website for more info. :P
I did
and it says
Features
• Stepping motor provides smooth operation
• Ignition ON initiates self-luminescence gauge
• Lightning-like Opening/Closing mode
• Adjustable warning setting
• Self-diagnostics function monitors both sensor disconnection and short-circuiting during startup.
• Using High-brightness LEDs illumination and color can be chosen from whiter, amber, red,
green and blue.
so are these different ? or can the warning setting be adjusted?
I did
and it says
Features
green and blue.
Hey mate,
they are adjustable. you have to read the manual after you buy them and you'll know how to do it. :blink:
Cheers. :)
hey mate u reckon u could get a pick of the cup holder and the ring holder..just wanna see which 1 id prefer
cheers
hey mate,
the choice for cup holder and ring holder is for shadow gauges only.
AMS gauges comes in ring holders only.
Cheers. :D
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
