Updated 26/6 Blitz Dual Sbc, Apexi Super Catalyzer Cat, R33 Turbo, Turbosmart Vee-port Bov $90, Jun Bl Muffler $125, R33 Master Cylinder, Z32 Afm
I HAVE HAD A LOT OF PMS WHERE BUYERS HAVE SUGGESTED I COMBINE MY LAST THREE FOR SALE THREADS WITH UPDATES SO I HAVE CREATED THIS COMBINED THREAD HOPE THIS IS EASIER.
Selling the follow parts all located in Adelaide but will post at buyers expense. Contact me via SMS on 0404998591 or PM me. Not looking for SWAPS unless you have a FC Datalogit, Wideband O2 Sensor kit, RB Splitfire Coilpacks or a good aftermarket clutch setup to suit R33 GTS-t.
UPDATED 26/6/2008
Brand New Blitz Dual-SBC Spec S Electronic Boost Controller complete in box to suit any turbo car - Price $310 Pickup or $325 Delivered
R32 GTR Radiator in excellent condition perfect upgrade for R32/R33/Cefiro stock radiators as twice as thick! - Price $180 SOLD PENDING PAYMENT
Apexi Super Catalyzer (Catalytic Converter) with Heat Shield in new condition only used for a couple of thousand kms removed from R34 GT-T but may fit other models. These are over $1200 in Oz even Nengun sells for $900+ delivered check out http://www.nengun.com/apexi/super-catalyzer . These are extremely high flowing catalytic converters with the best build quality I have ever seen check out the flanges with Apexi embossed! Price - $450 $350
R33 Stock Turbo in excellent condition made 213rwkw on 11psi on last tune before removing to fit GT30. Turbo never saw more than 11psi as I didn't want to damage it Morpowa were convinced I had a high flow as the turbo made good power and felt extremely strong on road test. Comes complete with lines etc Price - $350
Turbosmart Type 2 Vee Port BOV complete with intercooler pipe & fitting this is the modern version not the old blue/orange version often seen. Price - $120 $90
JUN BL Muffler - this is the rare model like Marky used to run with the angle cut tip with JUN BL embossed into the side of the tip complete with ~60cm of pipe and flange! Cost $600 new used for the last 11 months sell for $250 * $125! *
Set of 6 x S15 Injectors removed from my RB25DET in perfect condition good for over $250rwkw - $340 Delivered
Brakes & Hubs etc
R33 Front Calipers complete with lines, pads, clips, shims, pins etc - Price $280 SOLD PENDING PAYMENT
[R33 GTS-T Brake Booster + Master Cylinder (Non ABS) - Price $100
R33 Front Hubs, Uprights etc - Price $200
GAB 8 Stage Damper Adjustable Shocks complete with lowered springs ready to bolt into your car. Shocks are in excellent condition, have been fully dissembled and checked, absolutely no leaks or knocks and can be adjusted from stock stiffness to rock hard in seconds. Perfect for those who want more control over there handling at the click of a dial. These will fit R33/S14/S15 although were removed from R33. Price $125
Brand New R33/R34 Front Cusco Camber Adjustable Upper Arms have just been trial fitted but never driven on as have changed plans on car so now up for sale - Price $450 $425
Z32 AFM Plugs + ~30cm of loom ready to splice or wire into your loom to run Z32 AFM in excellent condition. Come complete with instructions on wiring into SR, CA & RB Powered Vehicles
Price - $30 Delivered or $20 pickup
Z32 AFM Fitting Kit consists of a Z32 Pod Adaptor + bolts/nuts and Silicon Reducer to go from Z32 to stock intake pipe + Bonus Z32 AFM Plug. Price $60 Delivered
Pair of R33 Front Seats in excellent condition. The drivers seat has a small tear in bolster nothing major. This is the comfy plush velour type model with the adjustable side bolster wings for more support through corners etc.
Price - $150
Freebies
Pair R33 Front Castor Rod Chassis Mounts
Pair S13 Rear 4 Stud Hubs
Location - Adelaide
Contact - SMS 0404998591 or PM
RECENTLY SOLD
Advance Headers Dump & Front Pipe Combo to suit RB
R34 Rear Brake Setup
17" Rays Gramlights + Spacers
Edited by nigelswazi
Sorry forgot to add the following pics and the Personal Steering Wheel
Blitz Dual SBC
Z32 Fitting Kit
Personal Steering Wheel in excellent condition - Price $100
u wanna swap the non abs master for a abs master? just im doing the rb25 conversion to my sil which is non abs and upgrading to the 33 brakes. hook me a pm bud
Nigel - how much muffling does the JunBL give? Looking for something reasonably quiet but well flowing...
Hi mate,
Was reasonably quiet in comparison to many mufflers I have experienced so they must use good quality packing within sounds like it would suit your application.
Hey mate how much for your sbc?
The following have now all sold
Turbosmart V-Port BOV
R33 Brake Master + Booster
Sold pending payment
R32 GTR Radiator Pending Payment Sat
R33 Front Calipers Pending Payment Sun
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
