Whats a ceffy cage worth? Might get rid of it once its here to help pay for my brake upgrade an complance. Also anyone got any idea on the power it could make? rb25,kkk-26 turbo(or someshit), 8 injectors,aftermarket comp,metal headgasket,intercooler thinks thats it! Rotas are so more simple.
